10 years agoGuidelines to avoid Negative Slack with State Machines
Hi, I m working on a hardware which uses a hardware block (Lets call it x), which does communication with a host machine, does processing based on the request given by the host machine, and gi...
10 years ago --- Quote Start --- This could definitely be debated, josyb! --- Quote End --- Try me! Almost every state machine I write, inside an Avalon_ST module, has asynchronous outputs. Can you show me how to do that with a synchronous (only) process?
