10 years agoGuidelines to avoid Negative Slack with State Machines
Hi, I m working on a hardware which uses a hardware block (Lets call it x), which does communication with a host machine, does processing based on the request given by the host machine, and gi...
10 years ago --- Quote Start --- A two- or a three-process state machine is the better approach, unless you have something simple that fits perfectly in the synchronous process. --- Quote End --- This could definitely be debated, josyb!
