9 years ago
Got problems on running 32*32 multiplier vhdl code running on quartus at linux OS
HI everyone please help me. my code is library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.all; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity mult32bit is generic ( DATA_WIDTH : integer := 32 ); port( a : in std_logic_vector(DATA_WIDTH-1 downto 0); e : in std_logic_vector(23 downto 0); --PARAM d : in std_logic_vector(7 downto 0); --PARAM c : out std_logic_vector((2*DATA_WIDTH)-1 downto 0) ); end mult32bit; architecture Behavioral of mult32bit is signal b : std_logic_vector(31 downto 0); signal right : std_logic_vector((DATA_WIDTH)-1 downto 0); signal left : std_logic_vector((DATA_WIDTH)-1 downto 0); signal left_shifted : std_logic_vector((2*DATA_WIDTH)-1 downto 0); signal new_right : std_logic_vector((2*DATA_WIDTH)-1 downto 0); begin b a(15 downto 0), b => b(15 downto 0), c => right ); MULTIPLIER_left:entity work.mult16bit port map( a => a(31 downto 16), b => b(31 downto 16), c => left ); left_shifted b(15 downto 8), c => left ); left_shifted
    Ok thank you very much for your kind help.you r very kind. Thanks
