9 years agoGot problems on running 32*32 multiplier vhdl code running on quartus at linux OS
HI everyone please help me. my code is library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.all; ---- Uncomment the...
9 years agoI will not do your work for you.
You need to work out what needs to be connected and correct the code. I dont know what you want to connect to those ports.
