9 years agoGot problems on running 32*32 multiplier vhdl code running on quartus at linux OS
HI everyone please help me. my code is library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.all; ---- Uncomment the...
9 years ago32*32 vhdl code is
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.all; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity mult32bit is generic ( DATA_WIDTH : integer := 32 ); port( a : in std_logic_vector(DATA_WIDTH-1 downto 0); e : in std_logic_vector(15 downto 0); --PARAM d : in std_logic_vector(15 downto 0); --PARAM c : out std_logic_vector((2*DATA_WIDTH)-1 downto 0) ); end mult32bit; architecture Behavioral of mult32bit is signal b : std_logic_vector(31 downto 0); signal right : std_logic_vector((DATA_WIDTH)-1 downto 0); signal left : std_logic_vector((DATA_WIDTH)-1 downto 0); signal left_shifted : std_logic_vector((2*DATA_WIDTH)-1 downto 0); signal new_right : std_logic_vector((2*DATA_WIDTH)-1 downto 0); begin b <= e & d; MULTIPLIER_right:entity work.mult16bit port map( a => a(15 downto 0), b => b(15 downto 0), c => right ); MULTIPLIER_left:entity work.mult16bit port map( a => a(31 downto 16), b => b(31 downto 16), c => left ); left_shifted <= left & "00000000000000000000000000000000" ; -- left_shifted <= std_logic_vector("sll"(unsigned(left), 8)); new_right <= "00000000000000000000000000000000" & right; c <= unsigned(new_right) + unsigned(left_shifted) ; end Behavioral; mult16bit code is library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.all; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity mult16bit is generic ( DATA_WIDTH : integer := 16 ); port( a : in std_logic_vector(DATA_WIDTH-1 downto 0); e : in std_logic_vector(7 downto 0); --PARAM d : in std_logic_vector(7 downto 0); --PARAM c : out std_logic_vector((2*DATA_WIDTH)-1 downto 0) ); end mult16bit; architecture Behavioral of mult16bit is signal b : std_logic_vector(15 downto 0); signal right : std_logic_vector((DATA_WIDTH)-1 downto 0); signal left : std_logic_vector((DATA_WIDTH)-1 downto 0); signal left_shifted : std_logic_vector((2*DATA_WIDTH)-1 downto 0); signal new_right : std_logic_vector((2*DATA_WIDTH)-1 downto 0); begin b <= d & e; MULTIPLIER_right:entity work.mult8bit port map( a => a(7 downto 0), b => b(7 downto 0), c => right ); MULTIPLIER_left:entity work.mult8bit port map( a => a(15 downto 8), b => b(15 downto 8), c => left ); left_shifted <= left & "0000000000000000" ; -- left_shifted <= std_logic_vector("sll"(unsigned(left), 8)); new_right <= "0000000000000000" & right; c <= unsigned(new_right) + unsigned(left_shifted) ; end Behavioral; my errors are Error (10349): VHDL Association List error at mult32bit.vhd(42): formal "b" does not exist mult32bit.vhd Line: 42 Error (10346): VHDL error at mult32bit.vhd(38): formal port or parameter "e" must have actual or default value mult32bit.vhd Line: 38 Error (10784): HDL error at mult16bit.vhd(21): see declaration for object "e" mult16bit.vhd Line: 21 Error (10346): VHDL error at mult32bit.vhd(38): formal port or parameter "d" must have actual or default value mult32bit.vhd Line: 38 Error (10784): HDL error at mult16bit.vhd(23): see declaration for object "d" mult16bit.vhd Line: 23
