11 years agoGlobal way to set NUM_PARALLEL_PROCESSORS 1 for all Quartus jobs?
I am trying to automate test flows with Quartus in UGE (Univa Grid Engine; formerly SGE) and machines in my farm are running into load problems because Quartus tries to set the default number of para...
11 years agoThanks. This does appear to work the way I was hoping. I have one follow up: it only works if I put assignments_default.qdf in the project directory like you stated. I saw some online documentation (maybe dated) saying you can also place this file in $QUARTUS_ROOTDIR/quartus/bin for a more global solution. When I tried this it didn't work. Is there a "higher level" I could apply this setting than the project directory (anywhere under $QUARTUS_ROOTDIR or $HOME/.altera.quartus)?
Thanks, Jeff
