8 years agoGlobal memory access 512 bit width constrain?
Hi I'm building 2d fft for image processing from the design example provided by Altera, namely modify it to take advantage of Hermitian symmetric: use N/2 point fft to perform a N point real...
8 years agoI did more tests, you are right about the compiler combining the stores in the if/else branches, that's why it have two layers and cascading write units have large latency.
If both branches have 9 writes it's would use one 1024bits write, thought more bandwidth usage but the latency is small and that's what I care about. But in my case the 9th write in the else branch is a "void write" and may cause wrong output if kernel execution ordering is not sequential (not sure if it is, I think I read it somewhere that it's not guaranteed, but it is sequential in my experience) I wish programmer could just specify "don't try to share write unit between branches" or "use largest bandwidth necessary in any one branch"
