8 years agoGlobal memory access 512 bit width constrain?
Hi I'm building 2d fft for image processing from the design example provided by Altera, namely modify it to take advantage of Hermitian symmetric: use N/2 point fft to perform a N point real...
8 years agoHi HRZ
I made the picture larger. It's not all case that write to global with more than 512 bits will this situation occur, e.g. without the if else branch. You can try to compile the code below and see the difference in the system viewer when line in question is marked out. Thank you.__kernel void test(global float2 *restrict dest, global float2
*restrict in, int i)
local float2 buf;
int where = get_local_id(0);
int N=64;
buf = in;
buf = in;
buf = in;
buf = in;
buf = in;
buf = in;
buf = in;
buf = in;
if (i){
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf; // this line
else {
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
dest = buf;
