10 years agoGetting Signal Tap to discover the last time a trigger condition happens
Hi, I'm debugging a communication Interface between my FPGA Design and an external Microcontroller. It should transfer about 1000 packets of data via SPI, but always fails during the transfer. ...
9 years ago --- Quote Start --- Set the trigger position to pre-trigger and then set up the sample qualification to capture what you want to see after the trigger condition occurs. This will cause the samples you don't care about after the trigger to not be stored in the buffer. The sample discontinuities will be marked if you enable that option. --- Quote End --- What do you mean by "set up the sample qualification"?
