Getting ModelSim Intel Edition to work on Ubuntu 17x and higher.
Thank you both for your answers, your responses worked for me too for "Ubuntu 18.04.4 LTS"!
- fogl6 years ago
Hello everybody,
I am still having problem with ModelSIm(Quartus 19.1) on Ubuntu 18.04.1
I did all the above, but i still get an error (please see below). The '/modelsim_ase/bin$ ./vsim' is working and opening the GUI,
Info: Start Nativelink Simulation process
executing command line: ip-make-simscript --nativelink-mode --output-directory=myProject_iputf_input --spd=/home/xxx/myProject/qipsip/ddr_in.spd========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : max10
Quartus root : /home/xxx/intelFPGA_lite/19.1/quartus/linux64/
Quartus sim root : /home/xxx/intelFPGA_lite/19.1/quartus/eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : none
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation/modelsim=======================================================
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script /home/xxx/intelFPGA_lite/19.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Warning: File myProject_run_msim_rtl_none.do already exists - backing up current file as myProject_run_msim_rtl_none.do.bak11
TCL READ VARNAME
Error: NativeLink simulation flow was NOT successful================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: NONE
Nativelink TCL script failed with errorInfo: can't read "family_independent_lib_list(none)": no such element in array
while executing
"set my_lib_list $family_independent_lib_list($language)"
(procedure "::quartus::sim_lib_info::get_family_independent_sim_models" line
invoked from within
"::quartus::sim_lib_info::get_family_independent_sim_models $language $tool $hdl_version"
(procedure "iputf_get_sim_models" line 13)
invoked from within
"iputf_get_sim_models $family $language $rtl_sim $tool"
(procedure "get_sim_models_for_design" line 10)
invoked from within
"get_sim_models_for_design $lang $rtl_sim "modelsim""
invoked from within
"if [ catch { open $msim_do_file_name w } msim_do_file ] {
nl_postmsg error "Error: Can't open file $msim_do_file_name: $file_id"
set msim_do_file_n..."
(procedure "gen_msim_script" line 69)
invoked from within
"gen_msim_script args_hash"
("eval" body line 1)
invoked from within
"eval gen_msim_script args_hash"
invoked from within
"if [ catch {eval gen_msim_script args_hash} msim_do_file_name] {
error "$::errorCode" "$::errorInfo"
} elseif {$script_mode == 0} {
post_message..."
(procedure "launch_sim" line 108)
invoked from within
"launch_sim launch_args_hash"
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if [ info exists ::errorCode ] {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $..."
invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
set status 1
set save..."
(procedure "run_sim" line 74)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
error "$result" $savedInfo ..."
(procedure "run_eda_simulation_tool" line 334)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
