Getting ModelSim Intel Edition to work on Ubuntu 17x and higher.
Hi thanks for this guide. I ran it and now my '/modelsim_ase/bin$ ./vsim' is working and opening the GUI,
But sadly the '/modelsim_ase/linuxaloem$ ./vsim' that Quartus is using still does not work (same crush log sadly).
any suggested step you think might help?
- GPete37 years ago
I think I've got a solution for you to launch RTL simulation with ModelSim FROM Quartus.
In Quartus (18.1 with Ubuntu 18.04 LTS) -> Tools -> Options
Tab General -> EDA Tool Options
In ModelSim-Altera, browse to /home/XXXXXXXX/intelFPGA_lite/18.1/modelsim_ase/bin
Please note /modelsim_ase/bin and NOT /modelsim_ase/linuxaloem who doesn't work for me like you.
LEt me know ! Work for me !
- HMeye65 years ago
with all of the above I am able to run the modelsim GUI via the vsim command.
But so far I can NOT start modelsim via quartus "Run Simulation Tool". If I attempt it, I get the following error:
Info: Info: Successfully spawned ModelSim-Altera Simulation software
Error in startup script:
Initialization problem, exiting.Initialization problem, exiting.
while executing
"Transcript::action_log "PROPREAD \"$key\" \"$value\"""
(procedure "VsimProperties::Init" line 59)
invoked from within
"VsimProperties::Init $MTIKeypath"
(procedure "PropertiesInit" line 18)
invoked from within
"PropertiesInit"
invoked from within
"ncFyP12 -+"
(file "/mtitcl/vsim/vsim" line 1)
** Fatal: Read failure in vlm process (0,0)Does anybody know how to fix this?
- HMeye65 years ago
Nevermind, it works now. I had specified a wrong path... my bad.
