bteddy
4 years agoGetting errors when I run analysis and elaboration.
I have a verilog file "10ustep_stepperdriver.v" attached.
Using Quartus II 64-bit ver.13.1 web edition.
I was trying to run analysis and elaboration to get a RTL netlist (schematic).
I...
bteddy
4 years agothanks for the reply.
Not my code.
Came from another board, can't find author.
So, I should named the top-level entity in project 10ustep, and the module name should be the same "10ustep"?
How do I get it to create the schematic so I can do the wires?
sstrell
4 years agoYes, the top-level entity name must match. Just select "Set as top-level entity" from the Project menu with this file open in Quartus.
As for your second question, I'm not talking about a schematic. This is Verilog code and you need "wire" signal declarations for all named signals in the design like you have for QA, QB, QC, and QD.
