bteddy
4 years agoGetting errors when I run analysis and elaboration.
I have a verilog file "10ustep_stepperdriver.v" attached.
Using Quartus II 64-bit ver.13.1 web edition.
I was trying to run analysis and elaboration to get a RTL netlist (schematic).
I...
sstrell
4 years agoYou're getting all those warnings because you are defining a whole bunch of signals without creating signal (wire) declarations.
The error is most likely because you've named the top-level entity in your Quartus project 10ustep, but the module name in this code is DRV_10uSTP. Change the code or change the name of the top-level entity for the project.
