getting error "Error (16031): Current Internal Configuration mode does not support memory initialization or ROM. Select Internal Configuration mode with ERAM" while compiling NCO IP core with MAX10-16MDAF device.
- The ERAM preload is disabled when you select the dual configuration images mode.
- When the ERAM preload feature is set to OFF, features that require initialization of onchip RAM will not work.
The ERAM preload option is set to OFF by default.
Selecting Single Compressed Image with Memory Initialization or Single Uncompressed Image with Memory Initialization configuration mode will enable the ERAM Preload option but will reduce the size of UFM available.So we have same solution as you mentioned.
Anand
- yann124 years ago
Hi, I try to configure a double port RAM on the DE10-Lite Board (10M50DCF484C7G) with a .mif file.
But the problem is when I synthesize the whole thing, I get an error :
"16031 current internal configuration mode does not support memory initialization or rom. select internal configuration mode with eram."
But... when i go into Device->Device and Pin Options->Configuration->Configuration Mode, i only see 2 options :
1. Single Compressed Image
2. Single Uncompressed Image
I do not see the option "Single uncompressed image with Memory Initialization" which would make the error above go away.
I try it on teh 15.1 and 18.0 version, same issue...
Is there a solution to configure a mif file on this kind of board ?
Thanks for your help
Yann
