I have the similar problem. I am doing the tutorial "Using the SDRAM on Altera’s DE2-115 Board with VHDL Designs" which have SOPC builder to generate VHDL file.
In top level entity light, there is already SOPC generated nios system is defined and instantiated as:
ARCHITECTURE Structure OF lights IS
COMPONENT nios_system
PORT ( clk_0 : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
out_port_from_the_LEDs : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
in_port_to_the_Switches : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
zs_addr_from_the_sdram_0 : OUT STD_LOGIC_VECTOR(12 DOWNTO 0);
zs_ba_from_the_sdram_0 : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
zs_cas_n_from_the_sdram_0 : OUT STD_LOGIC;
zs_cke_from_the_sdram_0 : OUT STD_LOGIC;
zs_cs_n_from_the_sdram_0 : OUT STD_LOGIC;
zs_dq_to_and_from_the_sdram_0 : INOUT STD_LOGIC_VECTOR(31 DOWNTO 0);
zs_dqm_from_the_sdram_0 : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
zs_ras_n_from_the_sdram_0 : OUT STD_LOGIC;
zs_we_n_from_the_sdram_0 : OUT STD_LOGIC);
END COMPONENT;
BEGIN
--¡¡ Instantiate the Nios II system entity generated by the SOPC Builder.
NiosII: nios_system
PORT MAP (
clk_0 => CLOCK_50,
reset_n => KEY(0),
out_port_from_the_LEDs => LEDG,
in_port_to_the_Switches => SW,
zs_addr_from_the_sdram_0 => DRAM_ADDR,
zs_ba_from_the_sdram_0 => DRAM_BA,
zs_cas_n_from_the_sdram_0 => DRAM_CAS_N,
zs_cke_from_the_sdram_0 => DRAM_CKE,
zs_cs_n_from_the_sdram_0 => DRAM_CS_N,
zs_dq_to_and_from_the_sdram_0 => DRAM_DQ,
zs_dqm_from_the_sdram_0 => DRAM_DQM,
zs_ras_n_from_the_sdram_0 => DRAM_RAS_N,
zs_we_n_from_the_sdram_0 => DRAM_WE_N );
DRAM_CLK <= CLOCK_50;
END Structure;
Then why again separate file is generated without entity and component as:
--Example instantiation for system 'nios_system'
nios_system_inst : nios_system
port map(
out_port_from_the_LEDs => out_port_from_the_LEDs,
zs_addr_from_the_sdram_0 => zs_addr_from_the_sdram_0,
zs_ba_from_the_sdram_0 => zs_ba_from_the_sdram_0,
zs_cas_n_from_the_sdram_0 => zs_cas_n_from_the_sdram_0,
zs_cke_from_the_sdram_0 => zs_cke_from_the_sdram_0,
zs_cs_n_from_the_sdram_0 => zs_cs_n_from_the_sdram_0,
zs_dq_to_and_from_the_sdram_0 => zs_dq_to_and_from_the_sdram_0,
zs_dqm_from_the_sdram_0 => zs_dqm_from_the_sdram_0,
zs_ras_n_from_the_sdram_0 => zs_ras_n_from_the_sdram_0,
zs_we_n_from_the_sdram_0 => zs_we_n_from_the_sdram_0,
clk_0 => clk_0,
in_port_to_the_Switches => in_port_to_the_Switches,
reset_n => reset_n
and upon compilation giving following error:
Error (10500): VHDL syntax error at nios_system_inst.vhd(2) near text "nios_system_inst"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration"
When I remove this additional file, the compilation is successful but I am afraid of loading on FPGA concerning it may damage with incomplete/wrong program.
Any suggestion?
Thanks in advance
