AKAYA
8 years agogetting an error of target processor paused failed
I have designed a normal hello world program in NIOS2 using quartus. While running the c code its giving an error as target processor paused failed. The clk_in_reset is being connected to the debug...
AKAYA
8 years agoHi,
thanks for the reply
I have set the Reset vector and the Exception vector in the NIOS2 CPU properly.
The clock pin has been assigned properly. I even tried with regenerating the eclipse file but the problem still exist.
