AKAYA
8 years agogetting an error of target processor paused failed
I have designed a normal hello world program in NIOS2 using quartus. While running the c code its giving an error as target processor paused failed. The clk_in_reset is being connected to the debug...
Abe
8 years agoAre you getting the following error when using NIOS2:
Using cable "USB-BlasterII [1-1.1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
If so, then you haven't set the reset vector of the NIOS2 processor. To fix this do the following:
- Open your NIOS2 system in QSYS/Platform Designer.
- Select the NIOS2 CPU to bring up its Properties page.
- Select the Vectors tab, and under Reset Vector MEmory : select the on-chip memory instance or the debug memory slave.
- Do the same for the Exception vector Memory.
This will depend on your design and what you want to do when a reset occurs in the design. If you want to processor to go to the start of your code after reset, set it to the on-chip memory setting.
Save and Generate the system. Build the project and try to download the code to the Kit. It should work now.
