AustinTatious's avatar
AustinTatious
4 years ago
get_service_paths yields no service paths
When I run "get_service_paths master" and "get_service_paths jtag_debug" in the Quartus system console but it yields an empty string. When I open the Quartus Prime Programmer and hit "auto detect", my two JTAG ID's show up. Is there something that needs to be done for my jtag paths to show up in the system console?
  • Without the project design files, there's not much you can do.
  • sstrell's avatar
    sstrell
    That system is empty. To use the master service type, you have to connect the host (master) interface to other components in the system. You're just exporting that interface. What's it connected to?
    Also, of course, you have to regenerate the system, recompile your Quartus project, and re-program the device.
    • AustinTatious's avatar
      AustinTatious
      So to be clear, we received a board with the Altera chip on it which should have already been configured with the host (master) interface configured. After looking through the batch files we were given they only seem to establish the jtag connection but not upload any configurations to the chip. The fact that we aren't seeing the master service after the board is powered and the jtag connection is established means that we need to open the original project used to compile the fpga in the first place and diagnose what the problem is. Is there anyway to do that without the original project? Thanks for your help so far, this has been immensely useful.
  • ak6dn's avatar
    ak6dn
    What does: get_service_types return?
  • I ran "get_service_types", then ran "get_service_paths" for each of the service types I found. Here's the results. I bolded the commands that yielded results and underlined the ones that didn't. Let me know if I can provide more information.
    %get_service_types
    alt_xcvr_custom
    alt_xcvr_reconfig_aeq
    alt_xcvr_reconfig_dfe
    alt_xcvr_reconfig_eye_viewer
    alt_xcvr_reconfig_mifwriter
    bytestream dashboard
    data_pattern_checker
    data_pattern_generator
    design
    device
    hard_prbs_checker
    hard_prbs_generator
    hssiconfig
    io_bus issp
    jtag_debug
    loopback
    marker
    master
    monitor
    packet
    plugin
    processor
    slave
    sld
    trace
    trace_db
    transceiver_channel_rx
    transceiver_channel_tx
    transceiver_debug_link
    transceiver_reconfig_analog
    % get_service_paths alt_xcvr_custom
    % get_service_paths alt_xcvr_reconfig_aeq
    % get_service_paths alt_xcvr_reconfig_dfe
    % get_service_paths alt_xcvr_reconfig_eye_viewer
    % get_service_paths alt_xcvr_reconfig_mifwriter
    % get_service_paths bytestream
    % get_service_paths dashboard
    % get_service_paths data_pattern_checker
    % get_service_paths data_pattern_generator
    % get_service_paths design
    % get_service_paths device
    /devices/10M04D(A|C)@1#USB-0
    % get_service_paths hard_prbs_checker
    % get_service_paths hard_prbs_generator
    % get_service_paths hssiconfig
    % get_service_paths io_bus
    % get_service_paths issp
    % get_service_paths jtag_debug
    % get_service_paths loopback
    /devices/10M04D(A|C)@1#USB-0/(link)/JTAG
    % get_service_paths marker
    % get_service_paths master
    % get_service_paths monitor
    /design_instances/monitor
    % get_service_paths packet
    % get_service_paths plugin
    /plugins/com.altera.systemconsole.busanalyzer.internal.BusAnalyzerPluginProvider
    /plugins/com.altera.systemconsole.dashboard.internal.DashboardPluginProvider
    /plugins/com.altera.systemconsole.designs.internal.DesignsPluginProvider
    /plugins/com.altera.systemconsole.driver.internal.DriverPluginProvider
    /plugins/com.altera.systemconsole.gdbserver.GdbServerPluginProvider
    /plugins/com.altera.systemconsole.gui.desktop.DesktopPlugin
    /plugins/com.altera.systemconsole.internal.plugin.jtag.JtagPluginProvider
    /plugins/com.altera.systemconsole.internal.plugin.jtag.aji.AJIConnectionProvider
    /plugins/com.altera.systemconsole.internal.plugin.memory.MemoryPluginProvider
    /plugins/com.altera.systemconsole.issp.internal.ISSPPluginProvider
    /plugins/com.altera.systemconsole.monitor.internal.MonitorPluginProvider
    /plugins/com.altera.systemconsole.plugin.pli.PliDeviceProvider
    /plugins/com.altera.systemconsole.scripting.UserScriptSupport
    /plugins/com.altera.systemconsole.scripting.ui.ConsolePlugin
    /plugins/com.altera.systemconsole.sldhubchannel.SldHubPluginProvider
    /plugins/com.altera.systemconsole.tcpchannel.TCPChannelPluginProvider
    /plugins/com.altera.systemconsole.toolkit.ToolkitPluginProvider
    /plugins/com.altera.systemconsole.trace.drivers.TraceDriversPlugin
    /plugins/com.altera.systemconsole.trace.gui.basic.TraceViewMenuPluginProvider
    /plugins/com.altera.systemconsole.trace.manager.internal.TraceManagerPluginProvider
    /plugins/com.altera.systemconsole.transceivers.internal.TransceiverPluginProvider
    /plugins/com.altera.systemconsole.usb.USBConnectionProvider
    % get_service_paths processor
    % get_service_paths slave
    % get_service_paths sld
    % get_service_paths trace
    % get_service_paths trace_db
    % get_service_paths transceiver_channel_rx
    % get_service_paths transceiver_channel_tx
    % get_service_paths transceiver_debug_link
    % get_service_paths transceiver_reconfig_analog
  • sstrell's avatar
    sstrell
    Does your Platform Designer system design include the JTAG to Avalon bridge or some other bridging component (like a Nios processor)? Without that, you can't use those services.
      AustinTatious
      That is an excellent question and my gut tells me no. We received the code from the development team with a batch file to download the fpga configuration to the altera chip. I'll look around to see if the project file is in there so I can add a bridge component to the design. Hopefully that'll fix the problem.
  • I went into Qsys and added a JTAG to Avalon Master Bridge and saved the test.qsys file with my other quartus files, but when I went to
    test "get_service_paths master" I still get nothing. Should I have my .qsys file saved somewhere else? Is there something else I'm missing?
  • Does the answer from sstrell helps in your case?
    It seems that your Platform Designer system is empty/incomplete as mentioned.
    p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
  • This points me in the correct direction, but I'd like to confirm a path forward towards a solution before I mark anything as a solution yet.
  • sstrell's avatar
    sstrell
  • As this thread has reached a closure, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Richard Tan
