9 years agoGet error when compiling 'hello_world.cl'
when I use this command to compile an OpenCL kernel: c:\intelfpga_pro\16.1\hld\board\de5a_net_i2\tests\hello_world> aoc -v --board de5a_net_i2 .\device\hello_world.cl -o .\bin\hello_world.aocx --...
9 years agoTerasic has two BSPs, one for v16.0 and one for v16.1. Your log points to BSP incompatibility with Quartus. Make sure you are using the v16.1 BSP, and not v16.0. If you are using the v16.1 BSP, then you should contact Terasic and report the issue.
