9 years agoGeneric One-Hot Multiplexer
I am looking for a way to dynamic instantiate a multiplexer of N channels which has a one-hot encoded select. My current hard-coded version for a 3 channel system looks like this:
signal Ch...
9 years agoIf you're happy to use VHDL 2008, you can avoid the annoying (IMO) std_logic_2d type:
--in a package:
type slv_array_t is array(integer range <>) of std_logic_vector;
entity combmuxs is
generic (
WIDTH_D : natural := 4 ;
SIZE : natural := 16
port (
D : in slv_array_t( SIZE - 1 downto 0)(WIDTH_D - 1 downto 0) ;
Sel : in std_logic_vector(SIZE - 1 downto 0) ;
Q : out std_logic_vector(WIDTH_D - 1 downto 0)
end combmuxs ;
architecture a of combmuxs is
function smux3( d : slv_array_t ; sel : std_logic_vector)
return std_logic_vector
is
constant r : std_logic_vector( d(0)'range ) := (others=>'0');
begin
for i in d'range loop
if (sel(i) = '1') then
return d(i) ;
end if ;
end loop ;
return r ;
end function ;
begin
process( D , Sel )
begin
Q <= smux3(D , Sel) ;
end process ;
end architecture;
