kh12
4 years agoGenerating a Simulation File for ATLPLL IP
Hello, I am using the MAX10 dev board. Following instructions for creating the PLL is easy, however as seen in the following document (https://www.ece.ucdavis.edu/~bbaas/180/tutorials/using.a.PLL.pdf...
ShengN_altera
4 years agoHi,
Go to Assignments > Settings > EDA Tool Settings > Simulation. Then set Tool name and EDA Netlist Writer settings. Should see simulation file generated after EDA Netlist Writer compilation. Remember to set the Tool Executable location in Tools > Options > EDA Tool Options
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- kh124 years ago
I am looking to generate a verilog file to run on modelsim. With past versions (using altera pll instead of ALTPLL) I used to get a folder like: pllname_0002 and in it I had a .qip file and a .v file. When I follow these instructions I don't get that simulation verilog file.
