11 years agoGenerating a Qsys System with qsys-script
Hi all, I'm using a tcl file to create a Qsys system. the system contains a HPS. When i run qsys-script utility, it's stops at the HPS commands --- Quote Start --- $ qsys-scrip...
11 years ago --- Quote Start --- Look at the log file created during Qsys generation. If there is nothing obvious in the log file, file a Service Request with Altera. Please post any response to this list so that others can see your solution, thanks! Cheers, Dave --- Quote End --- Found this solution/workaround on the website. Supposedly installing support for the Stratix devices can solve this. Unfortunately I don't have a subscription license, so no fix for me :cry: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05082015_486.html If someone has a workaround for the workaround, or if someone from Altera has a timeline for when this will be fixed, please let me know. Cheers!
