11 years agoGenerating a Qsys System with qsys-script
Hi all, I'm using a tcl file to create a Qsys system. the system contains a HPS. When i run qsys-script utility, it's stops at the HPS commands --- Quote Start --- $ qsys-scrip...
11 years ago --- Quote Start --- I think a problem with this tool? --- Quote End --- No idea. Compare the log files from a working version and a non-working version and see if you can see the difference. If you do have an example that works under 12.0 but not under 14.1, then send that to Altera when you file a Service Request. Chances of getting a response are much better when you can show a problem. Cheers, Dave
