11 years agoGenerating a Qsys System with qsys-script
Hi all, I'm using a tcl file to create a Qsys system. the system contains a HPS. When i run qsys-script utility, it's stops at the HPS commands --- Quote Start --- $ qsys-scrip...
11 years agoHello,
I've the same problem. I've read tcl from de0nano. I've generated this to test, it's ok. For my de1soc, qsys-script seems blocked on add_instance hps_0 altera_hps 14.1 without this line the qsys file is generated, with these line nothing append. Someone has an idea about this problem ? I have quartus 14.1 with service pack. Thank you very much Gwenhael
