generated clocks or derived clocks "... without an associated clock assignment"
- 5 years ago
Thanks for the quick reply!
The .sdc file was of course already in the Project. Otherwise, I would not have seen the critical warning(332049) for my malformed “create_generated_clock“ command, right?
But I found the solution! Your mention of the "Timing Analyzer" made me re-read its manual, especially about the “create_generated_clock“ command! The command must be correctly stated for my example above:
create_generated_clock -name any_name -source [get_ports {CLOCK_50}] -divide_by 128 [get_pins {I2CCLK[6]|q}]With this, the warning (332060) disappears and also the results of the "Timing Analyzer" become more plausible!
Jan
We do not receive any response from you to the previous reply that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
