generated clocks or derived clocks "... without an associated clock assignment"
- 5 years ago
Thanks for the quick reply!
The .sdc file was of course already in the Project. Otherwise, I would not have seen the critical warning(332049) for my malformed “create_generated_clock“ command, right?
But I found the solution! Your mention of the "Timing Analyzer" made me re-read its manual, especially about the “create_generated_clock“ command! The command must be correctly stated for my example above:
create_generated_clock -name any_name -source [get_ports {CLOCK_50}] -divide_by 128 [get_pins {I2CCLK[6]|q}]With this, the warning (332060) disappears and also the results of the "Timing Analyzer" become more plausible!
Jan
usually, what i will do is right click and insert constrain in the sdc files. Make sure the nodes can be find from there.
