8 years agoGenerated clock
Hello, i will create a generated clock and need your help. I have a counter (1 to 2500), which increments every rising edge of clk. Then i set enable to "1" for one clock cycle and set it ...
8 years agothere is no clock input in U4. It stores the ADC samples (sampling frequency 1MHz). Whenever i have a rising edge of enable (generated by U6), the outputs of U3 and U4 should be updated.
So, when i use the enable as clock i need a generated clock constraint, right? Now, my enable signal is "0" till 2049 and "1" by 2500. How can i define it in my SDC file? Is it a proper way? To your suggestion with adding a clock: Just adding a clock to U4 and update the output whenever enable is set to "1"?
