9 years agoGenerate programmable file for MAX-V CPLD using Quartus Prime Lite
Hi, I have created the hardware design and would now like to generate a programmable file that will be flashed to my MAX-V CPLD. However, just compiling the design in Quartus does not seem to g...
9 years agoYou need a Programmer Object File (.pof) to program a MAX V part. SRAM Object Files (.sof) are for direct programming of volatile FPGAs.
Quartus Prime Lite should generate this by default. If it's not you need to scan the error/warning messages in Quartus as to why it hasn't generated it. Make sure you search your entire project folder structure for a .pof file in case it's not put it where you expect. Cheers, Alex
