18 years agoHi Marc, this is weird. Do you specify the library altera_mf using the "-L" switch when you simulate your source code? For example to run RTL simulation:
vsim -t 1ps -L lpm_ver -L altera_ver -L altera_mf_ver -L sgate_ver -L rtl_work -L work an_dcfifo_top_vlg_vec_tst If not sure, you can try run the native-link (Tools->EDA Simulation Tool->RUN EDA RTL Simulation) see whether you get the same error. Hope it helps.
