8 years agoGenerate an IP core using Quartus Standard Edition 30-days evaluation period
Hi, I have experience with other FPGA manufacturer and respective tools an now I have to send my VHDL code to other entity/person that will run in an INTEL FPGA (Stratix IV). That entity/pers...
8 years ago --- Quote Start --- What kind of ip core are you trying to provide. The trial version won't produce programming files or time limited IP cores. --- Quote End --- Thank you for your fast reply. I have my own VHDL code (written in pure VHDL) which performs several specific functions of an algorithm. I do not intend to produce programming files (bitstream), I just want to generate an IP from my VHDL code an sent it to other entity. Then, the other entity will receive that IP and integrate it in its project/development. The doubt is the following: with the Quartus 30-days evaluation period, am I able to generate an IP without any limitation (in time or other) ? Therefore, my IP (generated with Quartus 30-days evaluation period) can be used by the other entity (with Quartus licensed) in the next years without any limitation, correct ? Thanks in advance.
