13 years ago
GBX + pin assignment
Hi all,
There is something that I don't understand. I am trying to set up a PCIe x1 Core inside a Cyclone IV GX15 device (not a development board but my own design), with the Hard IP compiler and QSys.
My problem is during pin assignment. I see there is an ALTGX block inside the PCIe core, so this should be enough to tell Quartus that I am going to use a transceiver. So I assign 1.5-V PCML I/O standard to the positive side of the differential pair of the transceiver pin (E2/E1 for RX and C2/C1 for TX, that is the second GXB, there is nothing on the first GXB) but when I try an I/O assignment analysis if fails on :
Error (167038): Channel 0 transceiver atom "PCIe_TX" cannot be placed on the transceiver block channel 1 at location PIN_C2
Error (167038): Channel 0 transceiver atom "PCIe_RX" cannot be placed on the transceiver block channel 1 at location PIN_E2
Error (167038): Channel 0 transceiver atom "PCIe_TX(n)" cannot be placed on the transceiver block channel 1 at location PIN_C1
Error (167038): Channel 0 transceiver atom "PCIe_RX(n)" cannot be placed on the transceiver block channel 1 at location PIN_E1
Where did I make my mistake ? or is there something stupid like "if you use a GXB, start with number one !".
Thanks for your help,
Erik.
    Can I then maybe just ask someone to point me to the right document ? (I read tens so far, with no success)
    Erik.
    Hi Dave,
    This is very useful. I will try. I saw there is a good documentation with it, I should be able to implement all this without any problems now. thanks for sharing
    All the best,
    Erik.
