what kind of problems?
The Problems are:
Error (10884): VHDL error at fuzzy_rulebase.vhd(471): cannot access 'internal_control_pl' from inside pure function 'check'. Error (10884): VHDL error at fuzzy_rulebase.vhd(472): cannot access 'internal_control_pm' from inside pure function 'check'. Error (10884): VHDL error at fuzzy_rulebase.vhd(473): cannot access 'internal_control_ps' from inside pure function 'check'. Error (10884): VHDL error at fuzzy_rulebase.vhd(474): cannot access 'internal_control_z' from inside pure function 'check'. Error (10884): VHDL error at fuzzy_rulebase.vhd(475): cannot access 'internal_control_ns' from inside pure function 'check'. Error (10884): VHDL error at fuzzy_rulebase.vhd(476): cannot access 'internal_control_nm' from inside pure function 'check'. Error (10884): VHDL error at fuzzy_rulebase.vhd(477): cannot access 'internal_control_nl' from inside pure function 'check'. - Altera_Forum
either make the function impure or pass all those values in as parameters to the function.
Thank You Tricky for your Reply, I will try to do this.
I am a novice recently downloaded test this code.
I tried this code and appear that same messages,too. Is the fuzzy_rulebase parameters no give values? I cannot understand. Thanks
