8 years agoFSM miley machine
I'm new to Verilog. I was trying to write the next Finite State Machines (miley machine) in Verilog: https://i.stack.imgur.com/9rvCj.jpg One of the attached file (called FSM.v) is the pr...
8 years agoPlease refer to State machine templates provided with Quartus Prime.
In your Verilog file do this. Right click > Insert Template > Navigate to Verilog HDL > Full Designs > State Machines > Select Mealy or Moore state machines and Insert code to your file. Once you have a template feel free to modify this are per your requirement. Hope this helps. Best Regards, arslanusman2003 (This message was posted on behalf of Intel Corporation)
