8 years agoFSM miley machine
I'm new to Verilog. I was trying to write the next Finite State Machines (miley machine) in Verilog: https://i.stack.imgur.com/9rvCj.jpg One of the attached file (called FSM.v) is the pr...
8 years agoYou can also use the State Machine Editor that comes packaged with the Altera Quartus tool to draw your FSMs and have it generate the VHDL/Verilog code for you.
File -> New -> State Machine File. Here you can specify the inputs, outputs, states and transitions. Once done, select the language you want to generate (VHDL/Verilog) and click Generate. This will add the FSM and generated code to your project.
