8 years agoFSM miley machine
I'm new to Verilog. I was trying to write the next Finite State Machines (miley machine) in Verilog: https://i.stack.imgur.com/9rvCj.jpg One of the attached file (called FSM.v) is the pr...
8 years agoFor the SM you've put up, here's the Verilog Code..Since the outputs are on the States and not on the transitions, the state machine code will be like below.
module SM1 (
clock,
reset,
in1,
out1
input clock;
input reset;
input in1;
output out1;
reg out1;
reg current_state;
reg next_state;
parameter S0=0,S1=1,S2=2;
always @(posedge clock or negedge reset)
begin
if (~reset) begin
current_state <= S0;
end
else begin
current_state <= next_state;
end
end
always @(current_state or in1)
begin
out1 <= 1'b0;
case (current_state)
S0: begin
if ((in1 == 1'b1))
next_state <= S1;
else if ((in1 == 1'b0))
next_state <= S0;
else
next_state <= S0;
out1 <= 1'b0;
end
S1: begin
if ((in1 == 1'b0))
next_state <= S2;
else if ((in1 == 1'b1))
next_state <= S0;
else
next_state <= S1;
out1 <= in1;
end
S2: begin
if ((in1 == 1'b0))
next_state <= S1;
next_state <= S2;
else
next_state <= S2;
out1 <= 1'b1;
end
default: begin
out1 <= 1'b0;
end
endcase
end
endmodule // SM1
