11 years agoFrom opencl Kernel to IO ports or VGA
Hi, I am working on opencl applications : i am doing some image processing in opencl with DE1SOC board (cyclone V+ARM). I would like to implement physical IO ports of the board di...
11 years agoGanesh,
I am also interested in getting start with I/O channels and am using the DE1SOC as well. You mentioned that you found that you can implement Ethernet with channels. Have you done this? I was under the impression that if I viewed the board_spec.xml file, I should see a list of supported I/O interfaces. It doesn't appear to list any, not even ethernet. Would I have to generate my own BSP for I/O support? Thanks, Rudy
