9 years agoFPGA(Opencl) code work well in emulator mode, but can't finish run on the FPGA
Hello: When I run my FPGA(OpenCL) code in emulator mode, the result is right; but after I create hardware configuration file and run on the FPGA, the code is blocked and can't fin...
8 years ago --- Quote Start --- Now I have remove all the channels and use local memory buffers instead, the same as you say. But after I finish debug this version, I also want to try use channels, to see if use channels can increace performance. Is it necessary to do that I think? --- Quote End --- Hello, I was wondering, whether you were successful in running the kernel in channel configuration, I would like to follow your work, please keep us posted. Thanks
