9 years agoFPGA(Opencl) code work well in emulator mode, but can't finish run on the FPGA
Hello: When I run my FPGA(OpenCL) code in emulator mode, the result is right; but after I create hardware configuration file and run on the FPGA, the code is blocked and can't fin...
9 years ago --- Quote Start --- Yes, I have try, but still don't work. I have channel ording issues, so I think its caused by imbalance of access of channel. So, if this is the question, How do I change my code? --- Quote End --- Easiest solution is to put all of your code in one kernel, remove all the channels, and use local memory buffers instead.
