9 years agoFPGA(Opencl) code work well in emulator mode, but can't finish run on the FPGA
Hello: When I run my FPGA(OpenCL) code in emulator mode, the result is right; but after I create hardware configuration file and run on the FPGA, the code is blocked and can't fin...
9 years ago --- Quote Start --- 1) Is there any error output? 2) What hardware are you using? 3) Did you use a reference design? --- Quote End --- --- Quote Start --- Probably yes. Try putting a printf at the beginning of your kernel code to see if you get any output. I have never personally used printf on the FPGA itself. --- Quote End --- I printf some information at the beginning of my kernel, but they don't printf out.
