9 years agoFPGA(Opencl) code work well in emulator mode, but can't finish run on the FPGA
Hello: When I run my FPGA(OpenCL) code in emulator mode, the result is right; but after I create hardware configuration file and run on the FPGA, the code is blocked and can't fin...
9 years ago --- Quote Start --- 1) Is there any error output? 2) What hardware are you using? 3) Did you use a reference design? --- Quote End --- Thank you for reply! 1)There is no erroroutput. 2)Xeon + Arria10 3)I refer to Altera's channel exampls! Do you know any method to debug the code?
