10 years agoFPGA Beginner Question
Hi all, I want to deploy an error correction code on the FPGA, and I have to do a simple trick to set the parity equal to 1 in the beginning. Original code: assign nxt_parity=cur_parity;
10 years agoThis will just assign the next parity to be always 1. I dint think you want to do that. You need to use an initial block on your registers
