8 years agoFPGA Based Flight Control System
Hi, Everybody. I'm trying to build a flight control system that is based on FPGA. Is there anybody on this platform who has experience related to this topic, as i'm new into FPGA's and i coul...
8 years agoThank you very much for your feedback.
I have some basic knowledge about the FPGA and also some besics in VHDL, as i have been busy with this for the past 2 weeks. I have a Diagram of how i think the system should work. How can i send it to you, so you can view it? your email address maybe? Thanks in advance. Note: The FPGA will be used as a floating point for low level parallel processing and DSP will be used as a floating point for the high level serial processing. I need help with programming the FPGA to execute its task.
