11 years agoFound pins functioning as undefined clock
Hi, I'm encountering the following "Warning: Found pins functioning as undefined clocks and/or memory enables". I've gone into the "Classic Timing Analysis Settings", set an individual clock ...
11 years ago --- Quote Start --- Tricky Re: Found pins functioning as undefined clock What version of quartus are you using? you would be far better off using Timequest with SDC constraints --- Quote End --- I'm using Quartus 9.0sp2, unfortunately I need to use ACEX1K and this version of quartus is the last one that has compatibility with the ACEX devices. I worked out what was causing the warning. One of the default settings for the Classic Timing Analyzer is to ignore all user-defined clocks. Once I turned that off the warning went away.
