11 years agoFound pins functioning as undefined clock
Hi, I'm encountering the following "Warning: Found pins functioning as undefined clocks and/or memory enables". I've gone into the "Classic Timing Analysis Settings", set an individual clock ...
11 years agoHi all,
This project has taken a back seat recently, but I'm back to it now. I created a new project, copied the code over and set the individual clock in the Classic Timing Analysis Settings again (I also used the node finder to match the clock name with the correct node). Still coming up with the same error though. Tricky/Alex I've attached the .qar file, hope that helps. Thanks, Jesse
