11 years agoFound pins functioning as undefined clock
Hi, I'm encountering the following "Warning: Found pins functioning as undefined clocks and/or memory enables". I've gone into the "Classic Timing Analysis Settings", set an individual clock ...
11 years agoAre you using TimeQuest to setup your timing constraints? Try using the node finder feature to make sure you have the right name that TimeQuest will be able to match clock name and actual node in your design.
