11 years agoFound pins functioning as undefined clock
Hi, I'm encountering the following "Warning: Found pins functioning as undefined clocks and/or memory enables". I've gone into the "Classic Timing Analysis Settings", set an individual clock ...
11 years agoNothing in that code is causing your error - there are no undefined clocks and/or memory enables. Running it through Quartus, on it's own, confirms that.
So, I suspect there is a bit more code involved...? Cheers, Alex
