"Force Use of Synchronous Clear Signals" assignment
- 4 years ago
sload is used to set a value from a separate sdata input. You're just setting the output to 1 when this signal is enabled, which is not the intended behavior. If the device doesn't support this configuration (which seems to be the case) extra logic is added to give you the behavior you've defined.
Maybe what you really want is an asynchronous preset, which would set the output to 1 whenever enabled.
You should check the Design Recommendations user guide to see how to code for what you want:
thank you very much for your time
