18 years agoHi Brad,
you're right. The difference is in different compilers. I've tried the same thing as you. Compiled in Q72 does not give LPM_COUNTER, Q40 gives. From what I saw I have concluded that it makes no sense to use LPM_COUNTER at all then, if you use Q72. thanks for your time. cheers .d.
