For the instantiation of ddr3, when compiling to the fitter step, an error error occurs: 14566.
- 4 years ago
Hi Adzim,
Thank you for your reply!
I have solved this problem. The reason is that the PLL reference clock used for the first time cannot be routed to the bank where the DDR3 is located, so quartus prompts me with the above error message. When I changed another reference clock, the problem went away.
Ryan-SEU
As the error states, your placement selections are preventing the placement of a DLL for the memory interface.
When placing the pins in the Pin Planner, did you enable the DQ/DQS view to see the valid locations to place the DQ/DQS pins? Did you run the .tcl script that is created when you generate the IP (I think it's called pin_assignments.tcl)?
Hi sstrell,
Ryan-SEU
