13 years agoFor loop
hello I want to check an array. which one is quicker? using for loop or using a counter that counts up at the "posedge" of the clock. thanks
Your posts here indicate a fundamental misunderstanding about what Verilog HDL is. When you use Verilog to program an FPGA the Verilog code is not at all like a software language such as C or Basic. Instead, the Verilog code describes a hardware system composed of flip-flops, logic gates, etc. It does not tell the FPGA to execute Verilog statements. The FPGA is not a microprocessor that executes lines of code sequentially.
